Threads: 7
Thanks Given: 1
Have 2004 multispace desire 2.0 hdi, am having limp mode problems, hear a beep shortly after starting engine but no lights showing. Have not got handbook yet so don't know where management light should be or what colour etc.
2004 berlingo multispace desire 2.0 hdi
Threads: 32
Thanks Given: 13
It's a yellow light shaped like an engine.
You should see it when you first turn the ignition. It would normally go out after a second or two... If it's not lighting up then, the bulb must be bust / removed!!
The following 1 user says Thank You to tucker for this post:1 user says Thank You to tucker for this post
• Wirdip
