Threads: 12
Thanks Received: 1 in 1 posts
Thanks Given: 10
hi there i want to fit a towbar to my 09 plate berlingo mk3 is there a plug in socket for electrics at the tailgate i have told the electrics are a nightmare i have been quoted £440 in oban and £280 to fit in glasgow for job cheers :-)
Threads: 9
Thanks Received: 23 in 9 posts
Thanks Given: 1
Hi Jonathan , if you search my posts for ' perm. live in boot area of mk111 multispace' you will see that I found that you can wire a decoupling relay for connection of towbar wiring to berlingo car electrics. Pretty easy if you follow the guide , good luck!
Threads: 7
Thanks Received: 16 in 11 posts
Thanks Given: 2
i purchased a swan neck bosal one with relay electric kit £125 out of motor factors, half an hour and towbar was fitted and less than an hour for the electrics, straightforward connections, everything works as it should. £280 sounds ok for a mechanic for his work
Threads: 2
Hi,
Did you ever get the towbar wired up?
I have fitted mine but wiring has stumped me....
Threads: 35
Thanks Received: 119 in 88 posts
Thanks Given: 3
4
23-12-2014, 07:45 PM
(This post was last modified: 23-12-2014, 07:46 PM by ntm1275.)
Bought a secondhand removable swankneck towbar from a gentleman on this forum for £50 and then a genuine Citroen 13pin elctric kit for £126 from a dealer
The genuine Citroen kit was just plug and play
