bsi unit exchange
Threads: 6
Thanks Given: 2
Hi guys n gals, can I change my bsi unit for 2 nd hand one if I get the key that matches ?
My seat belt alarm still goes off even when seat belt connected, also window wipers cause alarm to go on/off intermittently, cheers for any help
Regards,
Hugh gibson.
Threads: 2
Thanks Received: 6 in 3 posts
Thanks Given: 7
Maybe you need a BSI reset,, this can be done but i'm not exactly sure how
Threads: 37
Thanks Received: 38 in 37 posts
Thanks Given: 11
What is the BSI guys the ECU?
Threads: 2
Thanks Given: 7
No V6,, BSI is the onboard computer housed underneath the passanger fusebox,, The ECU is engine control unit housed behind the battery
Threads: 6
Thanks Given: 2
Tried reboot, no joy and my bsi unit is on drivers side under and to right of steering wheel....2003 1.9 hdi
Threads: 2
Thanks Given: 7
15-04-2014, 03:36 PM
(This post was last modified: 15-04-2014, 03:37 PM by joemc20.)
i believe relays are built into BSI and cant be replaced,, but if it helps my 2002 1.9 has them disabled and works fine,, check it out,, some one else told me not to get 2nd hand BSI as they only have problems too.. i got a diagnostics check done this morning and all that came up was the mass air flow sensor,, was heavy on diesel and was told to change filter and clean sensor with contacts spray,, not to touch,,, hopefully it will help
seatbelt alarms disabled i mean
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
If you replace the BSI with a used one, you will need to change the engine ECU & key set as well if it is a hdi version, all must be off the same vehicle.
If the car is a 1.9, then the job is more tricky.
Threads: 6
Thanks Given: 2
Hi lighty, that's what I was led to believe, so that's a no no.
Joemc20, did you disable yourself or get in done in a garage ? My problem is because I live in france, tbey want to change bsi unit, 300 plus euro ! And I had hoped to be able to cancel or disable the alarm myself, or even tape over the little speaker lol, if I could find it......where is it ?
Threads: 2
Thanks Given: 7
Gibson,, not quite sure as i bought van 4 weeks ago and was disabled when i purchased,,, mine is a 1.9 diesel 2002,, but if there is anything i can help with just ask me as i can have a root around to see how they did it
Last Post: Alberts elbow
Yesterday 10:11 PM
Yesterday 09:32 PM
Yesterday 05:46 PM
Yesterday 05:17 PM
Potential Purchase!
Yesterday 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 07:07 AM
