Threads: 28
Thanks Received: 7 in 6 posts
I want to get a towbar for my van. I've seen kits on eBay considerably cheaper than from Citroen.. It's a 2012 L1 but I am unsure as to what kit I need.. I'm assuming all the holes are there ready from factory, for me to bolt it on?
2006 Citroen Berlingo 1.9 D - 69 BHP
1994 Renault Clio 1.8 16v - 212 BHP
1993 Renault Clio 1.8 RSi - 110 BHP
"There is no replacement for displacement"
Threads: 7
Thanks Received: 16 in 11 posts
Thanks Given: 2
got my bosal swan neck from motor factors £125 incl wiring kit, 6 bolts and half an hour and fitted, 1 hour later wiring done, no bumper cut,
Threads: 28
17-04-2014, 07:27 PM
(This post was last modified: 17-04-2014, 07:28 PM by til5101.)
I found this on ebay.. Item no. 380843965828 will this fit a mk3? Its only to tow a small trailer max weight about 400kg..
Threads: 15
Thanks Given: 46
5
Thats flange towbar & universal wiring kit. I'd pay a bit more & get Bosal swan neck & certainly a specific wiring kit if you are diy'ing. Swan neck towbar looks much neater.
Hi guys, brand new to this forum so I'm not sure if this is the right place to post it, I've just fitted a towbar to my berlingo van 2011, I've done the wiring as per fitting instructions, not the small bit I'm lost on is the 12v supply to the relay, I've ran a cable from front to rear and now reading some of the posts i didnt have to as there is a heavy white wire already there, Ive put a test on it but it's not live. Any reason why?
Threads: 29
Thanks Given: 67
20
Do you need to fit a fuse in the fusebox to enable the live to the rear ?
Threads: 23
Thanks Given: 50
29
There is a 20 amp fuse that needs to be fitted in the under the bonnet fuse box
Threads: 63
Thanks Given: 410
I've heard you have to buy the holes separately and they are not available from Citroen either !!!!
