  • 1 Vote(s) - 1 Average
The (in)famous suspension rattle
Recently got a 2013 Partner Tepee Family model - like Multispace.
It has a shade over 5,000 miles from new and came from Peugeot Factory Technical Dept. It has the usual annoying rattle on certain road surfaces - rough tracks, no problem, smooth black top ditto. It's the slightly poorer than perfect surfaces which produce the noise. I have a mate with an identical late 2009 car which had the same but much worse at 20,000 miles. He eventually shoved it back to the indy dealer who charged him in excess of £200 to cure it. It only improved it to where mine is now. The Peugeot dealer I bought mine from said they are 'Not the quietest of suspensions' and for now I left it at that. Did Peugeot/Citroen really produce a car with a 'Characteristic' noise in spite of the huge number I see on the road?I still feel that it is the ARB drop links - even though everyone says new ones will not cure it.
Has anyone tried a test drive with the links removed and the ARB supported? - on private land if there are any paranoid folk reading this.
I feel that the drop link lining material is just not compliant enough and might make a couple up myself with rose joints at each end.
Anyone made any improvement or do I just ignore it? I realise it's not like my XJ8 Jaguar, but it should not make noises like this. I know it's not likely to lead to catastrophic failure anytime soon, but as a time served Aero Engineer, it's not on.
The rear of my '08 rattles like mad when empty, but is completely silent when there is weight in the boot. It annoyed me that I couldn't find the source. I now just accept it as I usually carry quite a lot in the back.
If you do find the reason I would be interested to know!
I personally would start running tests to see what the problem is.
I'm sure that being an aero engineer you love having a tinker!
(03-07-2014, 04:46 PM)Solent Wrote:  The rear of my '08 rattles like mad when empty, but is completely silent when there is weight in the boot. It annoyed me that I couldn't find the source. I now just accept it as I usually carry quite a lot in the back.
I was always replacing these links with my Mk 1, virtually every MOT!
My 09 Mk3 is much better, but still once every 2 MOTs. Next time I replace them I will modify the ends with heavy duty ball joints with grease nipples.
my 63 plate enterprise model knocks on non perfect roads, not on big bumps though and is fine on Dual carriageway, if the van wasn't so 'floaty' I would remove my anti roll bars, as I have in my daily car, (it's so low and stiff there isn't any body roll) but I fear I'd end up in a hedge lol
63 plate Berlingo working hard.....
SOLVED: P20F6 fault
Today 07:18 AM
Coolant
Last Post: Martinze
Yesterday 08:24 PM
Leaking windscreen or aerial
15-04-2026 08:50 PM
