  • 3 Vote(s) - 3 Average
Off side brake light problem
My offside brake light not illuminating .Nearside and high level lights working fine .Checked bulb and fuse both fine .Any suggestions ?Sad
[-] The following 1 user says Thank You to Susan Mayer for this post:
  • Ol'Jeffers
hi susan,, more than likely in the connector block behind light cluster,,, check connections,, and check for bad earth,, if you have a multimeter check for power and earth,, if not, get a piece of wire direct from battery and try power,, then earth,, you will find where prob is
Hi will try that ,thanks for the advice
Welcome Susan! Hope you manage to sort that out!
The offside position light ,indicator and fog light illuminate too, just the brake light doesn't
could be a bad connection at the bulb source,, or in the connector block,, you need to check if you have 12 volts at the connection to the bulb
I was following a van the other day with an earth problem. Indicating left was fine till he pressed the brake then all the other lights went out and just the brake light was left on flashing. It looked like one of those old American cars where the brake light doubled as indicator.
Hi thanks for everyone's assistance , it was a connector fault which I have now rectified :-)
[-] The following 2 users say Thank You to Susan Mayer for this post:
  • Ol'Jeffers, RolyG
Last Post: stu76
Today 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
