  • 18 Vote(s) - 3.33 Average
What would be reccomended in restoring a Citreon Berlingo which will not start
Hi,
After 2 years of not being driven I decided to try to start my Berlingo, when the key is put in the ignition no noise is made and the car engine does not start. I would put this down to a dead battery, however I am unsure how to fix this problem, also i would love to have reccomendations for any other possible faults which may need to be restored before taking the car on the road.
[Image: W020090914542448169810.jpg]
coach outlet online,coach purses,Coach shoes--
Firstly, I would recommend checking your battery. I expect some members will be along shortly with more advice, in the meantime, have a look here:-
http://www.berlingoforum.co.uk/showthread.php?tid=815
Divine Intervention ????
At first, charge the battery. If battery is not charging, buy new battery.
If the car has been standing unused for 2 yrs & the battery has not been charged then battery will have probably had it. Check oil & water & then try jump starting or just put new battery on. One hopes handbrake is not siezed & discs are not too rusted. If car is over 3yrs old your first road trip will be to a prebooked mot test & you might as well get car serviced at same time because it will need it. It would be a good idea pump up tyres to correct pressure before you drive it.
Welcome to the forum mate, another one with something to advertise......:twisted:
MOT Emissions repeated fail
Yesterday 05:05 PM
Rear door filling with water
Last Post: Marsaday
Yesterday 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
