24-04-2014, 07:53 PM
Hi all, hoping some one can help me out,
My 1.4 y reg berlingo has been parked up for about 6 weeks, always run fine with no issues to talk of.
Finally got in her last night and started fine, decided to give it a little run to make sure the brakes weren't sticking as I live by the coast, ran about a mile down the road and pulled in to a car park to turn around and head home.
As I turned around, the car made a bit of a noise and just stopped working, the engine just stopped, no spluttering or anything just stopped.
tUrned the ignition over, and it's turning over, dash board lights coming on but will not fire at all.
Put it in first gear and managed to turn it over enough to get it to the side of the road, so drive train, gearbox etc all fine.
When turning it over I noticed the hazards cme on automatically (never done this before)
Returned to it this morn gin and got in it, turned it over and again turning over strong but won't fir and the HAzard warning lights came on again.
Towed it home, check timing belt etc and all looks well, disconnected battery and reconnected and still the same, just won't start.
Checked other electrical components, and as well as hazards coming on when trying to start the heater is not coming on, nor is the rear demist switch lighting up. Everything else appears to be working.
MAin problem is I live on an Island North of shetland and no auto electrition on the same island so really need some help and advice
Hope some of you guys and give some advice,
Cheers,
Clint.
Cheers,
Clint.
alut:
