Threads: 5
Thanks Received: 3 in 2 posts
Thanks Given: 1
thanks for A/C on my mk 1 bingo as it was 91 here near southend on sea but cool in the bingo
Threads: 32
Thanks Given: 13
My Mk2 needs a re-gas..... never get round to having it done though!
Threads: 30
Thanks Received: 99 in 44 posts
Thanks Given: 40
4
It was nice and hot in Southend today, I don't have a/c though. Could do with it lol
Lliam
70 plate Berlingo
Threads: 15
Thanks Given: 46
5
Yes a/c should be run for at least half hr per week all year. Certainly nice to have today.
Threads: 52
Thanks Given: 87
5
A/C was a must here yesterday. Got up to 94. Today supposed to be warmer then thunder and lighting in the afternoon.
Threads: 5
Thanks Received: 5 in 5 posts
Thanks Given: 8
I have AC but when I use it the temperature guage goes up quite alot, any ideas anyone??
Multispace 1.9D Mystery Machine.
Threads: 32
Thanks Given: 13
divingscubaboy, considered that, but it doesn't work at all. I think the volume is too low, so it won't even run.
I was going to take it anf get it checked for leaks then re-gassed. There's always something else to spend my cash on though!
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
@ Pitman: Number of reasons why temp goes up. When a/c on your engine drives a compressor putting the engine under additional load. If the system is low on refrigerant it will be working harder and the compressor will run for longer before cycling on/off. When cooling the air con system becomes very hot as the refigerant draws the heat out of the air to be cooled there is an additional rad to be cooled which iirc is in front if the engine rad. All this has an effect on the engine temp.
sent from a telephone that resembles a well known chocolate bar, dosen't taste like it though!
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
