Threads: 19
Thanks Received: 6 in 6 posts
think i must be the only berlingo owner with this ,many c4 owners suffer, strip down time,
2010 1.6 hdi 110bhp XTR
Threads: 15
Thanks Given: 46
5
It looks like its had some sealant added around the pipe.
Threads: 19
thankyou open space ,yes there is silcone all over the air doser metering unit ,now the plot thickens ,checking service history quote (oil leak from engine area done under warranty ) now the fix under warranty was to spread silcon all over it , to me this is not a fix ,and the part should been replaced this was in 29/12/2011 , now they new this fix would not last ,so they should put it right , contacted said citroen garage ,they going to ring me back .
Threads: 19
air doseur now resealed by my self as per citroen fix for this problem , so far no leaks ,alternator is dry ,so hopefully solved.
Threads: 7
Thanks Received: 4 in 4 posts
Thanks Given: 24
Just check mine, 2010 xtr 110 showing 41k miles. No leaks.....yet.
Thanks for reminding me about this.
David
Threads: 123
Thanks Given: 250
34
I started a similar thread in the M59 section, but this one seems to cover the subject too, although from a few years ago.
If anyone has a good fix for this, it would be interesting to see,
