Threads: 2
02-05-2014, 12:28 PM
(This post was last modified: 02-05-2014, 03:48 PM by lou.)
I have a 1998 Berlingo van with an original radio. I need to input the radio code, which I have, but can't figure out how to do it - any ideas? There's no handbook for the radio.
Threads: 8
Thanks Received: 5 in 5 posts
Thanks Given: 17
Tried using the station preset buttons?
Press button a few times to desired number...
I have a 2006 model with radio manual will look at it when I get next beer ....
Threads: 2
Tried pressing them but nothing happens, it only has 5 buttons and one of the numbers is a 9...
Threads: 2
As I said, I have tried pressing them and nothing happens.
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
A Citroen dealer should be able to give you a code.
I DO MISS MY BERLINGO
Threads: 2
philip - as it says in my original post, I have got the code already, that isn't the problem.
haulrs - thanks for that, but as I said before, nothing happens when you press the number buttons.
Thanks Given: 188
23
Try using the up and down arrows, press number 1 then use up/down arrow for the first number of your code. Then pre set 2 and so on until the code is entered. Then number 5 to enter code.
Are we there yet?????
