Threads: 19
Thanks Received: 18 in 11 posts
Thanks Given: 21
Our rear wiper motor seems to have packed up this week, fuses all seems fine, and I have found a scrappy who'll send me a working one, with 2 months warranty!, for £37.
My problem is how to remove the old / fit the new. It appears to be held in place with three aluminium 'screws' which seem very soft. Are they actually big pop rivets? Anyone got any experience with these?
Threads: 63
Thanks Given: 410
Citroen and Peugeot seem to use this type of fixing quite a lot, my window regulators in my old 306 were fastened in a similar manner. Don't quote me but off the top off my head, think they were 5mm in diameter but can't remember the length. If you struggle to get some locally, there are quite a few suppliers on the good old e-bay.
Good Luck
Threads: 19
Thanks Given: 21
So, they are pop rivets then? they are about that diameter, fitted in rubber washers presumably for damping purposes?
Threads: 41
Thanks Given: 82
6
It depends on the age of the vehicle as early ones were screw fixing and later rivets.
Where did you get your motor from? Mine has not worked since I got the berlingo.
Threads: 19
Thanks Given: 21
29-06-2011, 12:50 PM
(This post was last modified: 29-06-2011, 12:51 PM by jamesf.)
The car is a 2001 (Y reg.)
Just searched on ebay, scrapyard is in Bury, Lancs
There is another seller, citroen main dealer, selling rear wiper motors for £30, but these are for the two door model, not the single door up'n'over rear door. they also advertising a front wiper motor for £15! Seems cheap to me and I must admit I'm bit tempted by that if it's the right one as ours is a bit tempramental - maybe i shouldn't have mentioned it here come to think of it!!
Everyone I've spoken to says these fail all the time - and indeed this will be this cars third.
Bloke at the 'yard reckons can fit with small bolts rather than splash out on special Citroen pop rivets, but will see how I think it will all work out and update when I can. The rivets are 'only' £5 (but they look fairly fancy ones, with plastic / rubber inserts)
Everyone I've spoken to says the rear motors fail all the time - and indeed this will be this cars third.
