  • 1 Vote(s) - 1 Average
2.0HDi Crank/flywheel locking point
Anyone know where to lock the crank/flywheel off on the 2 litre HDi engine?
I know the cam is an M8 bolt at 8 oclock. Just stuck on where the crank/ flywheel locking point is.
its on the block behind the starter motor. undo the starter and you should see it in or near a dip in the cast about as wide as your thumb if the bolt does not go in just wiggle the crank abit
[-] The following 1 user says Thank You to bazza300383 for this post:
  • leeandstaz
One thing after another
Today 09:01 PM
Yesterday 10:41 AM
» Replies: 16
Yesterday 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
