Threads: 26
Thanks Received: 29 in 14 posts
Thanks Given: 14
28-06-2011, 10:48 AM
(This post was last modified: 28-06-2011, 10:50 AM by El Berlingo.)
Hi Mate,
Thanks for your reply. I managed to locate my Spanish version of the attached but now I have it in English I'm less likely to get confused! I have spent most of the morning trying to locate a service manual for the 2007 1.6 Hdi. Usual download sites but only in French for the 2007 model. Haynes do not appear to produce an up to date manual for the Berlingo. Did download one manual (and paid for it) which appears to be an on line service manual for Citroen agents. Not very appropriate as loads of technical stuff but not good on basic 'how to' stuff. I recently changed the oil filter (it has the paper cartridge replacement type) and was a bit concerned as to the positioning of it as the filter had an O ring locator plug. After a bit manoeuvring I noted that it could only really go in one way (the O ringed plug located into a tube in the bottom of the filter housing) but it would have been nice to have this confirmed with a diagram! Anyhow, it works, no funny noises or alarm bells/lights!
Kindest regards, El Berlingo
Threads: 5
Thanks Received: 23 in 3 posts
Thanks Given: 3
25-10-2011, 11:14 AM
(This post was last modified: 30-10-2011, 05:26 PM by Tenere.)
Hi folks
I also wish to start servicing my similar van but the handbook is a bit basic. I hoped to get hold of a Citroen workshop service schedule job list, the sort with check boxes for each task and check completed as I have for my Mazda. I did get hold of the Citroen TIS software and there is a service section but with no documents within for the Berlingo.
Does anyone know of such a document floating about?
'07 600x 1.6HDI 75 Berlingo (M59) short van
RPO: 11251
Engine: DV6B Gearbox: BVM5 BE4-5L
tudy: MK2 1.6HDi 75 short van '600' M59
'07, 80k
DV6B Engine
BE4-5L manual gearbox
Threads: 147
Thanks Given: 263
11
I will have a look/think and get back to you when i get home, i cannot think off the top of my head except for the new Haynes.
Threads: 26
Thanks Given: 14
Hi all,
I'm still keeping my eye open for a suitable service book which also shows the basic repair/replace jobs. Not too sure if the 'new' Haynes manual covers my particular model?
The menu kindly provided by Northman is a help with the service side of things but, personally, I would like a manual that shows HOW the procedures are conducted (replace brake shoes/pads, filters etc.).
Will let you all know if I locate anything.
Regards, El Berlingo
