  • 1 Vote(s) - 3 Average
bonnet release cable
The bonnet release cable on my berlingo has given up.can anyone advise on how to open bonnet please.i have pulled the cable to stretching point and it still wont open.
        Hi Spudd,
You could try the old D2 trick of getting someone to push down on the bonnet whilst trying to open it.
Hopefully the 2 attached photos will help. Access from underneath our 1.4 is good.
HTH,
Griff
Landmark
Ex 1.4 Berlingo Multispace
Which mark is your Berlingo?
I had this problem on a Picasso and managed to drill a discreet hole in the bend of the upper chevron on the front grille. This allowed for a screwdriver to be poked through to lever the cable attachment point to the open position.
I'm not near my Berlingo now, but will see if this can be done later Smile
0 to 60 - be patient, 0 to 100 - not in my lifetime! :eek:
It may be a slow Blue Slug, but it"s the only slow Blue Slug that I own :S
[-] The following 1 user says Thank You to BlueSlug for this post:
  • ulysses
Cheers both will give it a try.
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
