  • 13 Vote(s) - 3.15 Average
Rubber seals and locks
Hi there havn't been here a while, I think I spoke about the rubber seals that are glued to the frames along the top where the doors meet when closed, well mine are loose and I would like to replace them, can anyone advise where I can get them, also all the locks are tricky to open I have to stab in the key and turn quickly every time I lock and unlock, did source a link a while ago for a replacement set about £70 plus Vat but lost it. Its a 1.4 multispace forte (Y) there must be some guys out there with the same problem, on a lighter note:
Heard the one about the fat, alcaholic transvestite?...
All he wanted to do was eat, drink and be Mary!!!!!!!!!!!
Quick look on the Citroen service site looks to be about £110 per side - that's to do the front and rear doors and the long strip that goes above them both
00009023FF DR WEATHERSTRIP 41.62 GBP 49.94 GBP 49.94 GBP
00009023Z1 DR WEATHERSTRIP 32.62 GBP 39.14 GBP 39.14 GBP
00009023NL SEAL 17.44 GBP 20.93 GBP 20.93 GBP
That's inc VAT
(28-06-2011, 02:05 PM)Coco Wrote:  Quick look on the Citroen service site looks to be about £110 per side - that's to do the front and rear doors and the long strip that goes above them both
That's inc VAT
Tanks Coco, I only need the ones that fix at the top to the car frame, I tried to find the service site but no luck, could you post a link, thank you
Hope this helps - shows diagram/part no's etc
f you need anything else just let me know
Attached Files Thumbnail(s)
.htm   affiche.do.htm (Size: 32.17 KB / Downloads: 14)
  • caravan72
(29-06-2011, 01:29 PM)Coco Wrote:  Hope this helps - shows diagram/part no's etc
Cheers Coco, I found a link further down the forum but still trying to work out how to get to the parts section, think I'll have to register.
Did you click on the "affiche.do.htm" ? If so, did it open ? This should give you the text to go with the picture.
Sorry I couldn't get it to load together, but I am next to useless with computers - there's nowhere to put a spanner see?
Leaking windscreen or aerial
Last Post: Guanajuato
Yesterday 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
