  • 4 Vote(s) - 4 Average
Berlingo 2.0 HDI (2005) Cold Starting Issues
Hello
We have a problem with cold starting:
The glow plug indicator o the dash doesn't come on;
Solenoid doesn't click (solenoid is replaced with new);
No power to glow plugs (which have been replaced with new);
Fuses are all OK
Vehicle starts after prolonged churning of starter motor
We have tried putting 12 V directly to the glow plugs but although they seem fine and are drawing current the engine is still very slow to start.
Once warm the engine will start perfectly all day long, but the next day
Any ideas out there??:S
Hdi motors do not need glow plugs to start unless the temp goes below @-4 degrees, so forget that.
Obviously I have not seen your car, but the most common issue on the hdi is slow cranking speed, ie poor battery or most likely lazy starter motor.
The engine needs to spin quickly , ie about 300 rpm to make enough rail pressure to fire the injectors. If it's less they simply will not work.
Hi,
I have had problems with my Berlingo 2.0Hdi for the last twelve months or so. It never failed to start, even on very cold days but would crank for 20 to 30 seconds on first start of the day and was ok for the rest of the day.
It has been to 3 garages and they had told me that the glow plugs were not working, the relay needed replacing, the temperature sensor was faulty and lastly the engine management unit needed replacing (£800) all using their diagnostic computer. All giving the wrong diagnosis. All these parts were working perfect.
The starter motor was the problem, it got lazy, as Lighty says it needs to crank the engine above a certain speed for the injectors to fire and the compression to generate temperature in the cylinders (compression ignition). The cost of replacing the starter motor was £82.00 plus vat and one hours labour.
Tongue I'm a Happy bunny now
Hope this helps others with the same problem.
I have a 2004 2.0hdi. The glow plug light very rarely illuminates, then only for half a second on very cold mornings.
I wouldn't be surprised if it's your starter motor as mentioned above.
I had cold cranking problems, starter wouldn't spin engine fast enough and would kill the battery, so got one of these:
http://www.ebay.co.uk/itm/CITROEN-BERLIN...SwirZTtAGU
Never a problem since.
I've checked ours a few times and the glow plug light comes on at 2°c and under. I found that if I switch the ignition on then fit my seatbelt before turning the key to start the car it turns over faster than if I just get in and wind it straight over. It's as if the car cuts power to the electrics when it is first switched on.
Got same problems with mine.auto election reckons no feed to glow plugs.I tried telling him they don't come on till its really cold.but he said should still be feed their he wanted to put a separate switch direct to glow plugs.? But I've read loads on here and it always goes back to getting a new starter motor.witch way do I go??? New starter or a switch to glow plugs???
Assuming battery OK, and it's not turning very fast- New starter (and a new auto electrician)
(28-01-2016, 06:18 PM)Col Wrote:  Assuming battery OK, and it's not turning very fast- New starter (and a new auto electrician)
That's what I keep thinking. Get a new starter.turns a bit slower when its cold.but then its fine all day long..
Thumbs up for a new starter to.
When cold, does yours actually start eventually or does the battery die first?
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
