  • 1 Vote(s) - 2 Average
compression test
Help required please! when carrying out a compression test on a berlingo 1.9d 2006 ,do you screw adapters all they way in till they go tight like the glow plug .and do you put ptfe tape over the thread to stop leakage,and what is the best way of stopping engine from starting many thanks.ps also does anyone know the Hz reading for the timming belt tension thanks
This any help, (page 11).
.pdf   Cam belt.pdf (Size: 250.71 KB / Downloads: 8)
:thumbsup:
I thought the normal way of doing a compression test was to remove all the plugs and then test each cylinder at a time with the gauge
With the plugs removed it can't start
Found this for the DW10 engine.
.pdf   DW10 Engine compression test.pdf (Size: 113.32 KB / Downloads: 25)
Confusedalut:
  • nobelz66
(09-05-2014, 02:14 PM)Rustscrat Wrote:  This any help, (page 11).
:thumbsup:
thanks for the help but it wont download from here for some reason
Thanks for the information but I don't have a seems tension tester ,but was going to get a Hz tester so I could use it on my other cars ,I think ill just have to do it the old fashion way 90 degree twist.
Yesterday 02:50 PM
Yesterday 02:31 PM
Yesterday 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
