  • 1 Vote(s) - 2 Average
hello all
just to say hello all,
i just got myself a 1999 multispace 1.4 petrol in metallic blue, it looks good for its age, and only 80000 in the clock,
i will be looking for a few bits that it need like driver seat, that the metal of the chair is digging on me, it doesn't got a bit of rust believe me that i look for it, but nothing.
and i will be looking for advice or your experiences. thank you in advance.
:wave:
[-] The following 1 user says Thank You to omally for this post:
  • Ol'Jeffers
Hello omally welcome to the forum good to have you with us look's like you found a goodun just ask away i'm sure some one or two will be a long to help you Confusedalut: :thumbsup:
Welcome along! Confusedalut:
Hi & welcome.:wave:
thank you all for welcome,
i went to do test, and disappointing, fail!
a few things it was a simple fix (what it thought)
like the tire specification on rear axle (different size, that i didn't noticed) that i just sorted,
registration lamps one not working, the other one temperamental, first i thought it was the light bulbs, but when i replaced them it was no difference, if finished pulling out the whole wiring loom of the door, and on the flexy bit that goes from the door to the body it had many cables broken (that explained the temperamental behavior of the rear wiper that the tester thought it was unusual, now fixed too,
now the other bit, that i had no idea how to tackle
fail in emissions, it says:
exhaust emissions
at low idle (890 rpm) temperature 86 degrees
CO 0.38% is a fail if above 0.50%
HC 149 ppm
at high idle (2.800 rpm)
lambda 1.05 is a fail if not between 0.97 and 1.03 (FAILED)
CO 0.62 vol% if is above 0.30% is a fail (FAILED)
HC 256 ppm if is above 200 ppm is a fail (FAILED)
can you guys give me an idea of how to fix this?
many thanks
Are the plugs & air filter good? You could try running Forte or similar through it.:wave::thumbsup:
(11-05-2014, 07:20 PM)ron Wrote:  Are the plugs & air filter good? You could try running Forte or similar through it.:wave::thumbsup:
it failed again! on the same, emissions, :brickwall: and it got new air filter,spark plugs,coils. i ordered a lambda sensor, the one before the cat. hopefully it will be here in a few days, any suggestion on what else i should look at?
thanks
What were the results?
(23-05-2014, 10:54 AM)addo Wrote:  What were the results?
same as before! no change with all the extra bits i done to it
First off, have you checked compression?
Today 12:02 PM
Berlingo 2026
Today 03:17 AM
Yesterday 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
