  • 1 Vote(s) - 1 Average
[Steering & Suspension] Heavy Steering
Hi All
the PAS pump went on one of the vans which then decided to leak fluid all over the Alternator.
I've changed the Alti and the PAS pump (Both new units) and all was we all good, Steering was brilliant and everything worked as it should.
After a trip down the motorway I came off to find the steering has gone heavy again.
I have checked the following
- Power steering fluid
- AUX Belt
- Sprayed the U/J
-Turned the Steering wheel side to side to see if there was any air stuck in the system
All of the above came back normal as it should but the steering is still heavy unless the van is jacked up and then it goes light again (even with only one side jacked)
Does anyone have any other ideas on what the issue could be as the last few days have been driving be crazy trying to work out what hasd cause the issue.
Many Thanks
Chris
The strut tops can suffer wear, their wafer-thin bearings seize, rubbers fail causing incorrect camber, also look right up the strut in case the coil has broken near the top.
If it's all good you may have a faulty pinion valve in the rack.
(11-05-2014, 12:18 PM)addo Wrote:  The strut tops can suffer wear, their wafer-thin bearings seize, rubbers fail causing incorrect camber, also look right up the strut in case the coil has broken near the top.
Thanks for the reply addo
Could the bearings really have gone that fast?
I was only driving for maybe 20mins on the motorway before i came off?
Checked the springs and they are all fine there
Whats the best way to check the pinion valve on the rack?
Chris
Easiest way to check the pinion valve is by rack substitution with a known good one. I'm presuming you flushed the fluid after changing the pump?
That said, normal mode of control valve failure is hard steering in one direction only.
(11-05-2014, 12:52 PM)addo Wrote:  Easiest way to check the pinion valve is by rack substitution with a known good one. I'm presuming you flushed the fluid after changing the pump?
Yes the fluid was flushed after changing the pump.
I've got hard steering both ways so i'm unsure if that would stray way from it being the valve?
Chris
Pump the tyres upto 60psi that's what someone else done lol.
I DO MISS MY BERLINGO Heart
Just a thought,Colunm UJ seizing?Confusedcratch:
Rear light cluster removal
Last Post: phydaux
Yesterday 11:47 AM
Cranks but won't start
Last Post: MarkA67
Yesterday 10:45 AM
Last Post: BrianS
Yesterday 10:35 AM
ignition lock ggrrrrrrrrr
Last Post: Sikez2012
17-11-2025 10:07 PM
Engine Fan Running
17-11-2025 09:59 PM
Bettery Issues - A Solution.
17-11-2025 10:45 AM
Sound proofing windscreen
16-11-2025 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
