  • 4 Vote(s) - 2.5 Average
Electric Window
Hi guys, my 08 berlingo drivers electric window was a little funny lately (going down when i push up on the switch), and eventually stopped. Replace the regulator inc motor and worked OK for a day or 2, now it went down today and will not come back up!. I hear the motor click like its trying to lift but it dosent!. Any ideas?
Update,changed the switches and drivers window will still no go up
[-] The following 1 user says Thank You to kierc0857 for this post:
  • steelviper
Thanks guys!
Does the glass slide freely?
Can you operate it with Lexia or another comprehensive scan tool that "test fires" body equipment?
Glass stays down,new regulator fitted but all infernos a clicking of the motor,would the switch be an issue?
If you unclip the plastic lifter bits from the glass, can you slide it up and down easily by hand? Sometimes the run channel lining can get folded in on itself, this causes massive friction.
Also the command goes in a roundabout fashion. Switch to BSI, BSI to door unit. So you might have a problem with the BSI's output. Lexia will tell you if it "sees" the switch being pressed every time, or just sometimes.
Thanks mate
I presume plugging the passengers switch into the drivers windows and till not workin rules out switch issue?
Go my bsi reset yesterday and all was ok but this afternoon started the same thing again but luckily it came up.any permanent cure guys?????
OMG this is really wrecking my head,new regulator,new switch and still window not going up,just clicking noise from the door card,very occasionally it will go up in stages but rarely. Any help would really be appreciated guys!
Have you checked for water in the bsi?
Seems to me your bsi is playing up
[-] The following 1 user says Thank You to homeruk for this post:
  • kierc0857
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
