  • 1 Vote(s) - 2 Average
[Brakes] Click from rear when stopping
I noticed a click/ tick noise from the rear brakes ( 11 plate) when coming to a stop. Anyone have any ideas what could be causing this
My car started to make a strange noise when I was cornering. It sounded to me like it was coming from the front, but I asked my son to listen from outside the car and it was the rear brakes. The off side had worn to the metal, while the near side was still ok. Weird - no stuck calliper. Could you have picked up a stone? or has something in the mechanism broken? Are you sure it is from the brakes?
Other thing, my car started clunking when I went into reverse but when I changed the front brakes it stopped.
Just had another thought, you may have something in a tyre which you only hear as a ticking when the wheel is going round slowly. Can you drive the car somewhere very slowly to see if you can hear it before applying the brakes?
You Had Your SON on the out side of the berlingo when you were going round corner's you'll get locked up :eek: :whistle:
Yes, I hung him from the roof bars - cable ties on each wrist and ankle, worked wonders!
Teenage boys do have their uses.
[-] The following 1 user says Thank You to Grem for this post:
  • Kokain
(16-07-2014, 05:34 PM)Grem Wrote:  My car started to make a strange noise when I was cornering. It sounded to me like it was coming from the front, but I asked my son to listen from outside the car and it was the rear brakes. The off side had worn to the metal, while the near side was still ok. Weird - no stuck calliper. Could you have picked up a stone? or has something in the mechanism broken? Are you sure it is from the brakes?
im not sure I have looked for stones and stuff caught and garage tells me my breaks are alright but I ffited new pads and stuff and its still there
Have you had a garage check the efficiency of the brakes? An MOT station can do this (should be for very little £ ). If the brakes are up to MOT standard just turn up the radio!
Not your earrings in the ash tray?
(That was a vw commercial here)
Sent from my 3geesus using Tapatalk( it's ifail)
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
