  • 1 Vote(s) - 4 Average
leak of oil from sump
Hi recently my husband changed the oil pickup pipe on our 2006 berlingo multispace 1.6 hdi (we had a 'low oil' warning light coming on) and after some advice given on this forum discovered the filter was gunged up.
Anyway he changed the oil warning switch and the oil pickup pipe,but now we have a leak of oil from the sump. He has had the sump of again and put in some more sump sealant but leak is persisting. Has anyone any advice to offer on this or does anyone know if you can actually buy a proper sump gasket for this car or if it is just a sump sealant he has to use. Grateful for any advice.
The 1.6 hdi doesn't have a gasket, I remove plenty of them and never really have a problem . I just seal,them up with RTV silicone.
Maybe he distorted the sump when he first removed it, they take some levering off, and are easily bent. If he takes it off again, check it on a flat surface, a tap,with a mallet will easily straighten it out.
[-] The following 2 users say Thank You to Lighty for this post:
  • caleua, taxi
Be very careful to wipe off all oil residue on both the sump pan and the edge it mates to. Any oil there can make the silicone or whatever sealant fail to seal properly.
[-] The following 1 user says Thank You to Gadgetman for this post:
  • caleua
Last Post: Beaumotor
Yesterday 04:38 PM
engine light
Yesterday 09:25 AM
M59 1.4 Petrol question
19-03-2025 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
