18-05-2014, 06:31 PM
(This post was last modified: 18-05-2014, 07:00 PM by ChippyAndBeer.)
I'm currently installing a second/leisure battery (through a VSR) in my berlingo van. I know I could use the chassis as negative/ground for charging but i would prefer to use a designated pos+ and neg- cable to charge the second battery as efficiently as possible (whether that's overkill or not on my setup, would be another discussion..).
Normally i would connect to the negative lug/terminal on the starter battery. However, as most of you will know, this is not very accessible and i don't wanna mess with the original wiring (which again, is not very accessible). So i was wondering what would be the best part to attach the negative cable to.
One option I was thinking of, is the lug that is bolted on the passenger side wing and is used for jump starting ( http://www.berlingoforum.co.uk/showthrea...5#pid16345 , the second photo). As its bolted on, I guess this bolting could be used to attach a cable terminal as well. Feels kinda bomb proof though and is bolted in fairly thin wall, not sure if its meant to ever be unbolted or even worse, once its off maybe not possible to re-attach! Alternative would be to use a 19mm ID battery lug to connect to it like to a battery lug.
Any thoughts or comments or other/better options would be much appreciated :thumbsup:
alut:
