Threads: 44
Thanks Received: 67 in 56 posts
Thanks Given: 9
9
I have a lot of bits and pieces in case somebody needs something big or small. Let me know what you need and we if I have it we can sort out something on the cheap. Perfect if you need replacement. This stuff came from a Berlingo Desire model with modutop so it's either black or cream colour. Rear section carpet and metal frame also available. Just ask really....
Threads: 5
Thanks Received: 5 in 5 posts
Thanks Given: 22
Rear sliding door interior plastic trims and fixing studs?
Threads: 5
Thanks Given: 22
21-05-2014, 10:13 PM
(This post was last modified: 21-05-2014, 10:15 PM by ulysses.)
bottom cards and material covered top rails / arm rests? just below the glass, matey... only need the drivers rear slider but if price is right ill take the pair, i need the plastic christmas tree studs that hold 'em on too, if possible..
Threads: 5
Thanks Received: 4 in 3 posts
Thanks Given: 1
27-05-2014, 08:03 AM
(This post was last modified: 27-05-2014, 08:41 AM by omally.)
yes, they look about right, i saw the one on one berlingo for sale on eBay,but i cant find the pic. now, they looked about 2 inch thick, and they where up, on either corner of the ceiling, where the rear light is.
if it was on that one i saw, sure i could retrofit mine with them too. (hoping the speaker wiring is there too).
Threads: 44
Thanks Given: 9
9
Yes, mine doesn't have these speakers, they are something like 6.5" and the mounting is specific to the roof. Unfortunately they won't fit your vehicle as you won't have anywhere to slot the magnets in. Even under the plastic covers there is a big chunk of plastic sticking out where they bolt to. My idea was to remove the rear speakers from there to prevent large items getting stuck in the van, but that's simply impossible unless the whole plastic liner comes out.
If there is anything else you need, let me know.
Threads: 5
Thanks Given: 1
i will, thanks, i was going to put some sound on the back, due the kids want to hear the music, by putting the volume up, but them in the front we cant talk due it.
