  • 1 Vote(s) - 1 Average
[Steering & Suspension] nearside suspension
my 2004 berlingo went clunk on smooth tarmac and the rear suspension looks like its collapsed,theres no rear springs,the axle looks good as does the torsion bar and the shocks so wondered what it could be,i have a new axle incase from the scrappy
only thing i can see is that the bump stop had worn so bad its snapped into 2 bit of rubber
Attached Files Thumbnail(s)
Hello Simon welcome to the forum a recon one would be best the scrappy one you have mite be ok but you don't know how long it will last as it got grease nipple's on it if so grease it up. On your old one the torsion springs have broken in side also the rear brake's can be a pain to bleed Sad
the rear brakes are going to be more of a pain because like a div i didnt think ahead and put the handbrake on and that was a while ago so they have seized solid,were abouts is the torsion spring,with the wheels off the axle looks completely level and the shocks rebound as they should,i live up a farm track but it was when i got on smooth tarmac a big metal clunk
There are three bars in the back, check them all for failure.
Yesterday 10:07 PM
Yesterday 10:01 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
