  • 2 Vote(s) - 2.5 Average
Reset bsi on mk3 berlingo
Is there a way to reset the bsi on a mk3 without lexia?
Sure, there is a thread (ore maybe more) on the forum on how to do it. Just run a quick search.
[-] The following 1 user says Thank You to 3rensho for this post:
  • kierc0857
Cheers mate,saw one but not sure unfit works for the mk3
Will the bsi reset procedure quoted work for the mk3 ?
Got this from - here and have used it on my B9.
Don't buy a new Bsi (body control unit) for your Citroen until you have read this and tried a factory reset first. Very often the reset will solve a multitude of problems especially the ones that suddenly happened after you fitted a new battery to your Citroen or the ones that just 'appeared' form nowhere!
Wipers stopped working?
Central locking gone mad?
Windows stopped working?
Indicators and lights doing their own thing?
All of the above can be caused by a nutty BSi and often a reset is all it needs so try this....
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of many BSI related items.
[-] The following 5 users say Thank You to 3rensho for this post:
  • daviddb, hunnsy, kierc0857, photoman06, silverfox
Good answer , very handy to know procedure. Confusedalut:
Is this info on a sticky note ?
thanks 3rensho
I tried the reset procedure today hoping that it will resolve a problem I have where the rear wash wipe comes on randomly. Does the reset procedure have any kind of feedback like a beep or anything, so that I know the reset has been done? Otherwise I have no way of knowing if I actually got the procedure right or not.
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
