remaps ?
Threads: 21
Thanks Received: 24 in 21 posts
Thanks Given: 133
hiya, I've a 58 plate 1.6hdi im using for long distance couriering,done a bit of reading/searching in regards to egr valve, blanking plate or remap ? is it more beneficial to the engine and fuel economy ? mpg is the important bit for me as paid by loaded mile and even though ive given it regular oil changes (every 3 or 4 weeks ) the idea of it sludging up does slightly worry me, any advice plus or negative would be appreciated. Ian
Threads: 23
Thanks Given: 50
29
Hi ian you can get a green eco map little more power better mpg have the EGR deleted at the same time smother running  alut:
Threads: 21
Thanks Given: 133
I take it you'd recommend it then ? a mate in the trade advised against it through people coming to him with problems after having it done,just with the mileage I'm doing (80/90k a year) a bit better mpg would be beneficial and i take it removing the egr from the equation will help on the often mentioned sludging problem ? I'm new to all this so need to know before running in and putting my usual size 13's in it again :-)
Threads: 67
Thanks Given: 1,045
If "long distance couriering" ever means towards Ilkeston, you might chat to Lighty, who's a member here and runs an independent garage down that way.
• ians_lingo
Threads: 80
Thanks Received: 391 in 334 posts
Thanks Given: 164
17
(22-05-2014, 08:08 PM)ians_lingo Wrote: hiya, I've a 58 plate 1.6hdi im using for long distance couriering,done a bit of reading/searching in regards to egr valve, blanking plate or remap ? is it more beneficial to the engine and fuel economy ? mpg is the important bit for me as paid by loaded mile and even though ive given it regular oil changes (every 3 or 4 weeks ) the idea of it sludging up does slightly worry me, any advice plus or negative would be appreciated. Ian
If youre changng it monthly then its a lot less likely to develp sludge especially if youre using the correct stuff
• ians_lingo
Threads: 2
If you have the Siemens ecu then blanking the egr is a no no as it will more than likely throw it into limp mode.
A remap would certainly help you gain better mpg although don't expect miracles, the gains aren't huge although you might notice with the amount of miles you do.....
The following 1 user says Thank You to homeruk for this post:1 user says Thank You to homeruk for this post
• ians_lingo
Threads: 21
Thanks Given: 133
where/how do i check which ecu i have then,noticed a lot of the comments have mentioned this so need to find out first i suppose ? cant find anything about it using the search function,ie...location etc ...Ian.
Threads: 47
Thanks Received: 15 in 12 posts
Thanks Given: 4
Getting better MPG can also be down to your tyre pressures if you are carrying heavy loads make sure they are inflated to the correct pressure for the weight, Normally the pressure chart is on the drivers door column, also use the best petrol not the cheap ethanol rubbish as this not only makes your van perform better it lubricates and protects the internals.
The following 1 user says Thank You to pitpan for this post:1 user says Thank You to pitpan for this post
• ians_lingo
Threads: 21
Thanks Given: 133
Thanks pitpan,to be honest I can't expect the mpg to be much better,it's the 1.6 hdi and the least I've had is 57mpg once with a best of 63.9, rarely carry much at all weight wise,a decent sized passenger would probably weigh more,I was more interested in egr/dpf removal to clear its lungs out so to speak :-)
Sent from my iPhone using Tapatalk.......
"Your only here once,don't ruin it with living to work,work to live"
Thanks Given: 46
5
Can you get away with blanking egr & removing dpf these days. I thought this was being checked at MOT after Feb this yr? If most of your driving is fast motorway then you shouldn't have any probs with dpf & egr valve will be closed most of time anyway? Engine won't sludge up if correct oil used. Total Quartz ineo ecs is Citroen recommended.
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
Welding precautions
24-11-2025 12:37 PM
driveshaft tripod joint spring
24-11-2025 12:31 PM
