Threads: 2
Thanks Received: 1 in 1 posts
Could someone tell me can I disconnect my immobiliser it's the keypad one. If so is it the same as a saxo/106 once it's running just disconnect it and jobs a good en?
Threads: 41
Thanks Given: 82
6
Is that the one you put in the number and then S?
Threads: 12
Thanks Given: 16
37
Yes, disconnect the pad with it running and car will run all the time. Will reset if the battery gets disconnected though, so don't forget the code.
