  • 2 Vote(s) - 3.5 Average
Citroen Berlingo Mk3 V2.0
Hi! I'm a proud owner of a Citroen Berlingo Mk3 (restyling).. Actually this is my 2nd Berlingo... I had an accident with the 1st one and decided do buy another..
It's a Citroen Berlingo from July 2013, mk3 restyling. Here are the specs:
Engine: 1.6HDi 8V - TURBO DIESEL DV6ETED4 (FAP)
Transmission: CXVM BE4L (CP 17 X 71)
Power: 75 bhp @ 4000 rpm
Torque: 136 lb/ft @ 1750 rpm
Tyres: Michelin Energy Saver 195/65 R15
Here are some pictures of the day it arrived to Citroen:
[Image: ku7z.jpg]
[Image: ae0t.jpg]
[Image: itnz.jpg]
[Image: 61i7.jpg]
[Image: qgqm.jpg]
For those who don't know me, I'm a trackday addicted Big Grin
With ~200km's on the dash, i've decided to test the new toy on "Vasco Sameiro Circuit".. 17" Steelies with semi-slick tyres on and let's go!
[Image: 3hc3.jpg]
[Image: fg9a.jpg]
[Image: ed4w.jpg]
A few weeks later i've changed the suspension setup.. Unfortunately i don't have any pics because it was suposed to be only a test.. I've used Bilstein 909 inserts with H&R coil springs..
At the front i've choosen a spring rate of 3,15kg/mm and at the rear, 2,65kg/mm. Got the front ~30mm lowered and the rear ~40mm..
Very important too is the alignment setup.. After several setups tested on track, the ideal setup for me is:
Front: -3,2º Camber / +7º Caster / 0º Toe
Rear: -1,2º Camber / +0,15º Toe
I know it's nonsense trying to improve a van's handling to do trackday's & hillclimb 'cause it's a.... van! On the other hand, since my job is relationated with Automotive and Motorsport Engineering, it's been a challenge Smile
[-] The following 1 user says Thank You to Ricardo Mendes for this post:
  • addo
Im old fasioned
I ran mine gently for a few months first.
On December 2013, I went to the Dyno:
[Image: uo7v.jpg]
All stock, it measured a little bit more than i expected:
[Image: vajk.jpg]
83,6hp / 207,8Nm.. Not bad for a 75hp engine Big Grin
(27-05-2014, 07:20 AM)evdama Wrote:  Im old fasioned
I ran mine gently too, essentially on break-in period Wink Driving on a track doesn't mean you have to flat out every time Big Grin
On March 2013, i went to "Estoril Circuit".. It was the best trackday ever!
[Image: zmmj.jpg]
Here is a video that shows the friendly ambiance:
https://www.youtube.com/watch?v=7odNC2hA_HI
Another Portuguese on Berlingo Forum! Welcome!
I really like your Van!
keep up the Good Work!
It´s always nice to see people interested in projects on a Van, Like Berlingo! The Best Van on the Market Big Grin
[-] The following 1 user says Thank You to andre 21 for this post:
  • Ricardo Mendes
Looking good what camber bolts did you use for the front did you need spacer's for rear toe and camber ? Confusedalut:
Eccentric custom top mounts on the front and camber shims on the rear Wink
Oh the rear, you need to put camber shims between hub carrier and axle.. You got 4 bolts and you can "adjust" toe and camber with more or less shims:
[Image: p4.jpg]
This is a Mitsubishi Colt but the Berlingo axle is pretty much the same Wink
Actually I only run 20mm spacers on front.. At the rear, i've made new hubs, 22mm wider. Since i work a lot with CNC Machining, it was kind of easy to do that Smile
Thank's for the info i wish i had a machine shop to hand :thumbsup:
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
