  • 1 Vote(s) - 1 Average
interior light
Hi all I have a problem with front centre console roof and two back left and right interia courtesy lights work with the door switch but won't when work when you switch them on manually ! :brickwall:
Might be worth checking your fuses. From memory they have two positive feeds; one from the door locks opening and the other for manual operation.
Yeah as Addo said, i seem to recall the other fuse controlled the fag lighter and 12 volt sockets, replaced that and voila! Of course my problem might have been the other way round.. lights coming on from the roof switch but not when opening the door, it was bloody confusing at the time
Your right a simple 30 amp fuse thanks folks
[-] The following 1 user says Thank You to skyeblue for this post:
  • addo
Hello skyeblue welcome to the forum mighty addo does it again Confusedalut:
I blew my interior light fuse earlier this week whilst trying to fit a strip light in the back of my van. Are you sure it's a 30 am fuse? Mine had a 20 amp in it.
Any details on the wiring at all? I'd like to wire the permanent feed to another supply, like a seperate battery, as they cut out due to power management.
Citroen Berlingo XTR (2016)
- Modulo Top / Climate Control / Auto Pack / Airbags / Sensors & Camera
- Amdro Bootjump (camper conversion)
It's french leave the wiring alone. I've run a separate feed from the battery into the cabin to supply a permenant feed to one of the cig lighter sockets and up to the roof for my light bar. If anyone can tell me how to post pics via this tapatalk crap app I will add pics of the extra interior lights I've added as well
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
