  • 1 Vote(s) - 4 Average
clutch or gear box problem advise please
I noticed tonight that when car is idling I'm getting a low grinding noise that stops when the clutch is put in. I'm wondering could this be the release bearing cars only done around 40 thousand miles and if it is the bearing do wait for it to break? The noise is so low atm I'm worried garage will think I'm nuts and claim they can't hear it
Plus does anyone know what sort of money were talking cause the last time I.fitted a clutch to my old car it cost 800 quid
The symptoms you describe are those of a noisy gearbox input shaft bearing.This can be caused by a too low idle speed.Have you change the g/box oil? If not synthetic is what I would recommend.Confusedalut:Confusedalut:
  • steelviper
What Ron said,
Plus don't let it get to the point where it breaks it will only cost you more in the long run.
If what Ron recommends doesnt work then get a few quotes to replace the bearing.
Is the car under warranty?
[-] The following 1 user says Thank You to homeruk for this post:
  • steelviper
(31-05-2014, 09:26 PM)ron Wrote:  The symptoms you describe are those of a noisy gearbox input shaft bearing.This can be caused by a too low idle speed.Have you change the g/box oil? If not synthetic is what I would recommend.Confusedalut:Confusedalut:
Nope I haven't changed anything. I will speak to garage about getting the oil changed then. what would cause it to idle too low?
the noise goes away the minute you put the clutch in then comes back the minute clutch is raised when idling
(31-05-2014, 09:36 PM)homeruk Wrote:  What Ron said,
the cars warranty ended in march, I did but a 2 year auto care plan for AC when I bought the car but im not sure they would cover this and if there mechanics are actually any good or if id be better using my normal mechanic
Anyone ??
(01-06-2014, 04:09 PM)steelviper Wrote:  Anyone ??
Does the idle speed appear low? Modern cars don't have the good old fashioned adjustment screws.If the idle is low,a dose of fuel cleaner MAY bring it up.Confusedalut:
It's idling just under 1000 rpm as normal and exactly mileage is 040354 this noise seems to appear anytime you return to nuteral and stops when clutch is put in noise is still fairly quite but is there
[Image: sbrf28.jpg]
Change the gearbox oil.
If no better get the input shaft bearing changed.
Job done
Sods law the warranty ran out in march, a polite email to Citroen saying the bearing has failed and should last longer than 40,000 miles might get Citroen to change it.
Don't ask dont get....
  • steelviper
Just a quick update
Took my car down to the garage that I usually use and they have agreed that it is either the release bearing on the clutch or the input shaft and they recon to wait until it starts making the noise in under load before brining it in to be fix. which shouldn't be anytime soon
Now as I have an auto care warranty with Arnold Clark I have rang them to ask them about repairs and they have said they cant tell me if the input shaft is covered until they can remove the gear box and see the parts. is this genuine or is this some kind of stunt to lure me in and then say the warranty doesn't cover it after dropping my gear box out for a nice labour charge
Is the clutch heavier than before? This happens when the input shaft bearing approaches end stage failure.
sliding door panel removal
Last Post: mojito
Today 07:13 PM
Twin Cam Chain Snapped need some Parts Advice
Last Post: kingy1912
Today 01:10 PM
Rumbling Noise 55-65mph
Today 01:06 PM
XL tyres
Today 01:03 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
22-03-2025 09:52 PM
