Threads: 3
Hello All :wave:
Berlingo 03
im getting an intermittant beeping noise from somewhere in the dash. Sometimes its 1 beep sometimes 2 and sometimes 3 beeps. When this beeping occurs i have also noticed it knocks out the indicators for a few seconds whilst beeping?? its now driving me insane as you can only turn the volume up so much to ignore it on the cd player when you have a Take That CD in :whistle:
Anyone had anything like this- i have searched the forum for relevant threads but nothing jumps out at me
Appriciate any info thanks
Threads: 25
Thanks Received: 47 in 29 posts
Thanks Given: 23
I take it you do not get any clues on the multi display as to the problem ? I would check the brake fluid level and maybe look at the handbrake switch maybe a door switch? just guessing really
Threads: 8
Thanks Received: 31 in 26 posts
Thanks Given: 8
It will beep if the airbag light stays lit - it should go off within a few seconds of engine start normally. Always cured on ours by fiddling with the wires/plugs under the driver seat - tends to occur after the seat position's been adjusted.
Low fuel also makes it beep IIRC.
Threads: 52
Thanks Received: 82 in 67 posts
Thanks Given: 9
(14-07-2011, 05:03 AM)malbro Wrote: (10-07-2011, 01:24 PM)jimbo Wrote: I take it you do not get any clues on the multi display as to the problem ? I would check the brake fluid level and maybe look at the handbrake switch maybe a door switch? just guessing really
cheers as it happens the airbag light has now lit up ? and a spanner has appeared next to the millage. I did think it was down to the brake fluid but that is spot on
Anyone have any further thoughts on what it could be ??
thanks in advance
I have had both the "air bag failure" and the "spanner". As mentioned above, the air bag warning is usually cured with a fiddle of the wires under the seat as they easily come loose. The "spanner" means that a service is due soon. It should be accompanied by a figure of "miles to go". This can easily be reset yourself (details can be found in the handbook or searching the forum).
