Manifold O2 sensor
Hi all,
After Receiving the upstream sensor yesterday I duly went to try and remove the old one using the 22mm sensor socket that I purchased and fell flat on my face. After removing the downstream sensor in the exhaust pipe I thought that the one in the manifold would be a breeze only to find that it will not budge and that the socket is rounding the edges.
I do have a normal 22mm long socket that I can use but was wondering if I cut the wires can I reattached them using electrical connectors if I fail to budge the sensor. Also is it possible to heat up the manifold using a blow torch or would this do damage to it and the Cat.
Cheers, Pitpan
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
