1.9d forte multispace 2001
hi everyone,,, i just joined so might take a while getting used to this forum, . i have a problem i would like a bit of advice on ... my dials ie: speedo, rev, and lights on my dash are all out and flicker sometimes when driving , only light that comes on is airbag light and parking light? strange.... i believe it to be a problem with bsi unit or the instrument cluster itself , what could cure this ? also when i checked the bsi part number in my multi-space and the part is actually for a 1.4 petrol forte but mine is a 1.9d non turbo, it was working fine until about 3 months ago. sometimes when driving and i noticed that it was when the car got very hot the dials and lights would spring back to life for a short time. any help would be much appreciated
Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
my 2001 1.9d did exactly the same, second hand clocks from scrap yard for £20 and fixed
Threads: 2
Could be a bad earth on the instrument panel , have you checked this?
Threads: 2
Thanks Received: 6 in 3 posts
Thanks Given: 7
yes,, like homeuk says, check bad earth before changing anything. put in a 2nd independent earth wire if ya have to
checked earths and they are all ok , might just go ahead and try a second hand set of clocks, as long as it passes mot i dont mind about wrong mileage reading , i will get back and let you guys know how this went,
Threads: 2
Mileage should be stored in the ecu, changing clocks won't effect this.
If it did everybody would be changing clocks at sale time so they could sell a van/car with a lower mileage!
Threads: 2
Thanks Given: 7
i doubt that the clock is at fault,, most prob a bad connection along the wiring somewhere.. i do know that 1 fuse works most lights... it would be worth taking out the clock but still connected and start the engine up,, shaking the wires then and see what happens,,, i had something similar, it was deffo bad connection,, not just earth
Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 10
my 2005 multispace had problems with the mileage display the screen cracked when I took it apart to clean inside it (bit ocd but it did my head in seeing all the dust and grime in it) and I thought I would just buy a new cluster but I checked with my citroen garage if it was possible and they said the cluster was matched to the bsi and a new one wouldn't work. I ended up buying another cluster and taking the display out of it and swapped it over and it worked thankfully
Threads: 4
Thanks Given: 10
I have been told by an auto electrician that in some cases it will add the 2 mileages together but it depends on age of the bsi and clocks, better just getting the faulty clocks repaired I think.
Just google berlingo instrument cluster repairs and you should find a few company's that will do it and just find the cheapest
