door panels mk3
hi there does any body know on a mk3 how to take the front door panels off ,so I can change the speakers thanks tony
Have a look at the how to's i'm sure there's a thread on how to take the panel's off :thumbsup:
Had mine off recently to replace an outside mirror. Removed plastic around door opening handle, removed plastic cover over mirror mount and then used the special tool to carefully pop out the pins that hold the door cover in place. The tool is a curved plastic bit that has a forked (V-shaped) end. I bought a set like these.
thanks for that, is it clips around the handle thanks tony
Hi Toni,
Can I ask what make of speakers have you fitted and what size are they?
Anybody fitted rear speakers again what make and what size any issues?
Cheers Geoff
Rear seat belt breakage
Last Post: Mad one
Yesterday 06:09 PM
Yesterday 05:49 AM
11-09-2026 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
