radio
just removed old original radio/cassette on 07 berlingo ,trying to fit new cd radio ,do I need a new cage ,it keeps sinking into dash ,cheers frank
Have you swapped across the little rubber "snub" screwed onto the back?
Yes, the cage must match the radio but the snubber is often forgotten in the changing.
  • frankybhoy
(07-06-2014, 11:00 AM)frankybhoy Wrote:  just removed old original radio/cassette on 07 berlingo ,trying to fit new cd radio ,do I need a new cage ,it keeps sinking into dash ,cheers frank
How did you cope with the wiring?  Given up on changing mine as can't get the memory to work on the sony cd player despite switching red/yellow and buying autoleads connector.
GGGrrr.
Hi Chris.Ive just replied to your other post ,get yourself a test lead ,ive just found one in Toolstation for £1.73.item number 84459.Armed with this youll be able to test your cables.Its very easy to locate a permanent feed.
Last Post: Alberts elbow
Yesterday 10:11 PM
Yesterday 09:32 PM
Yesterday 05:46 PM
Yesterday 05:17 PM
Potential Purchase!
Yesterday 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 07:07 AM
