indictors
Hi I have just brought a berlingo last week and today when I put the indicators on then flash three times then they go off and the side lights come on but if I switch on the side lights first then the indictors work as they should
check your earth points in engine bay,, bad earth can cause it
(07-06-2014, 04:39 PM)joemc20 Wrote:  check your earth points in engine bay,, bad earth can cause it
do you now where then could be thanks
It can also be a fault with the stalks, or COMM unit as it's called. There is a fellow on here called "trustme" - he's in Bradford and can repair/refurbish many column units.
  • rwebb234
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
