  • 4 Vote(s) - 3.25 Average
whine after fitting new cam bel
Hi
Fitted a new cam belt on my berlingo 1.9D and notice I now have a whine coming from the engine that increases with acceleration. Does this mean the belt is too tight and what could be the reprocussions if any?
Brian
Yes, too tight. Most likely outcome is a leaky water pump.
  • brianthegas
(09-06-2014, 08:49 AM)addo Wrote:  Yes, too tight. Most likely outcome is a leaky water pump.
I renewed the water pump and associated pulleys at the same time as the cam belt,Wondering, could it be the aux belt?
What addo is saying is, if you continue to run with a belt that's too tight your shiny new water pump will start to leak, plus your risking snapping the belt.
A general rule of thumb is the belt should be able to be twisted 45 degrees no more no less.
[-] The following 2 users say Thank You to homeruk for this post:
  • addo, brianthegas
Is it definitely coming from the engine bay??
I had a permanent whine when I was driving. I located the problem and divorce has solved it!!! Smile
[-] The following 3 users say Thank You to tucker for this post:
  • addo, Gadgetman, royboy302
(09-06-2014, 11:56 AM)tucker Wrote:  Is it definitely coming from the engine bay??
Nice one TuckerConfusedillyme:
(09-06-2014, 10:51 AM)homeruk Wrote:  What addo is saying is, if you continue to run with a belt that's too tight your shiny new water pump will start to leak, plus your risking snapping the belt.
Thanks, I understand what addo is saying, and also made sure there was about 45deg twist, just to be on the safe side I will release the tension a little.
Mucho gracias amigo.Confusedalut:
Brian
Yes i have the same problem i find a regular greasing work's but not for long Rolleyes
If you contaminate a belt with coolant/antifreeze then it will screech like a knackered bearing. Spray a bit of water on the auxiliary belt and if the noise goes temporarily remove the belt and clean it.
[-] The following 1 user says Thank You to JohnM for this post:
  • brianthegas
valeo alternator CL15 rebuild
Yesterday 07:08 PM
Unusual Braking Problem
Yesterday 06:33 PM
Yesterday 06:19 PM
oil Sump
Yesterday 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Yesterday 04:34 PM
M59 1.4 Petrol question
14-03-2025 10:48 PM
14-03-2025 09:29 PM
» Replies: 27
14-03-2025 09:08 AM
Insurance Shocker !!!
14-03-2025 09:04 AM
13-03-2025 08:09 PM
