  • 7 Vote(s) - 2.86 Average
Sloppy gear change 1.6HDI, Mk2, 2006
Ok so just changed my gearbox to another one which runs completly smooth, but its got a new fault which the last one didnt!
The gear selection is now VERY sloppy, the stick in neutral when you wiggle it used to be under spring tension and would centre its self, now its loose and doesnt centre and gear selection is sloppy.
Going from 5th to Neutral is also weird and is like i kind of have to do a zig zag to get into it.
The garage told me that they reckon the selector gate in the box is faulty, but i am not so sure the whole gearstick just feels really slack and lifeless.
Goes into gear fine just the feedback from the stick is limp and lifeless!
Sounds more like a linkage issue to me. Any almost-whole cars nearby you can look at to compare?
See if you can reach the linkages and pull on them a bit.
(You may need to remove a few bits in the engine bay to reach down)
They should be pretty firm, no slack in the balljoints at all at all.
Well the gear linkage failed today and turns out all three are in really bad condition. I have bought the parts to change them. Any advice on how to get them off, best to do it from the top or under neath.
I can see the ball joints i just need to whack them off some how, best to use plyers or is there a way to get a hammer in there Smile
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
