  • 5 Vote(s) - 3.4 Average
Manifold O2 sensor pic
Hi all,
After huffing & puffing for the good part of an hour I eventually removed the sensor. I had to dismantle the sensor using a hammer so that I could fit a 22mm long socket which I had to hammer on so that it did not slip. I had to do this as the sensor socket that I bought was rounding the edges. I then had to use a 2ft breaker bar to move the sensor mm by mm as it was on so tight.
In the end I now have both sensors changed, the car is running more smoothly & the EML has not come on again...YET!
Today 01:49 PM
Yesterday 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
