Threads: 67
Thanks Given: 1,045
Yes, coolers do fail. Shop around, it's not just a PSA part.
Threads: 5
Thanks Received: 31 in 27 posts
Thanks Given: 2
Regarding your other post, I had the opportunity to study the cooling system on my 1.6hdi whilst sitting in standing traffic yesterday. My van usually runs at 80deg, but whilst sitting in standing traffic it slowly crept up past 90deg and the fans eventually came on as the needle reached the next mark which I think is 100deg and it dropped right back to 90deg. On the occasions that the van did move the air flow through the radiator bought the temperature down noticeably. I would not expect the temperature to get much above 90deg when driving unless you were driving up long hills with a lot of weight on and would only expect the fans to come on when stationary or moving very slowly.
If you had an oil and water mix I would expect emulsified oil (mayonnaise) on the inside of your oil filler cap, but not always. Leaking combustion gasses can leave an oil like deposit.
A garage can test your coolant to identify any contamination, but with the missfire it does sound as if you've lost compression on one or more cylinders.
When I did my head gasket it cost quite a lot in parts alone, I had the head skimmed which included re-cutting 16 valves, a new set of head bolts and a gasket set which came to around £280 and I also replaced the cam belt. (I got the head done at Blackburn Brothers in Preston 01772 822703 and they also supplied the gasket set and bolts.) Labour from a garage would put a big chunk on top of that as it is not a five minute job to get the head off and if the injector seals have been blowing it can be a real tw@ of a job to remove the injectors. The head won't come off without them coming out first.
As a tip if you do the job yourself; the manual says that you have to remove the fuel pump at the back of the engine, you don't, there is a short stud that needs to be removed where it bolts to the head.
The manual also says that you should not re-use the high pressure injector pipes, I did without any problems, just unscrew them from the injectors and bend them up a bit to make room.
Also mark up your injectors as they have to go back in the same cylinder.
Good luck.
Threads: 16
Thanks Received: 31 in 22 posts
Thanks Given: 3
I'm keeping my fingers crossed it's not the head gasket. Other than the splutter (misfire might be an exagerated way of describing what it did) it behaved normally all of this week with temp never going above 90 even when stationary or going up hills, and I recon I've done over 2,000 miles this week.
With 195,000 miles on the clock it may not be worth chucking loads of money at it if it turns out to be a head gasket problem even though it is in otherwise in good nick. I certainly wouldn't tackle a head gasket change myself, oil cooler looks simple to change but I'll probably just leave it to the garage. At least as it's a vehicle for my business I can offset the costs as a business expense.
Threads: 23
Thanks Given: 50
29
14-06-2014, 09:42 PM
(This post was last modified: 14-06-2014, 10:19 PM by Jed Clampit.)
Remember if you change the oil cooler there will some oil left in the cooling system even if you clean it well so don't panic if you still see some oil in the header expansion tank :thumbsup:
Threads: 2
Are your injectors clean?
Could be the rocker cover leaking?
Could be crankcase ventilation is blocked.
I would advise a through clean and see if it returns and were from
Threads: 23
Thanks Given: 50
29
15-06-2014, 08:35 PM
(This post was last modified: 15-06-2014, 08:36 PM by Jed Clampit.)
Wow that's a lot of oil as the man said ^ also check the O ring from the rocker cover breather to the turbo air intake
Threads: 16
Thanks Given: 3
Thanks for the replies. I've got it booked in at a local garage to be looked at on Tuesday morning, I'll update when I have a verdict.
