Thanks Given: 3
30-10-2016, 04:25 PM
(This post was last modified: 30-10-2016, 04:26 PM by Dappadanny.)
Afternoon all!
I'm Dan and soon enough I shall have a Berlingo. Just had a quick butch through common faults/things to look out for when buying one. So if you have any suggestions it would be appreciated.
No doubt you will hear from me again as I will be firing questions in my hunt for a decent van.
Thanks for your time!
Thanks Received: 69 in 66 posts
Thanks Given: 8
5
30-10-2016, 04:37 PM
(This post was last modified: 30-10-2016, 04:38 PM by Johny555.)
Full service history is a good start,and if the cam belts been changed,look at back wheels see if they are straight,if leaning in at the top,could mean new axle neede,,check all electrics work,make sure blower works on all speeds,check inside floor for damp,or wet,could be heater matrix leaking,
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
What kind of age and engine?
• Dappadanny
Thanks Given: 3
Brilliant tips thanks! Looking to get 2012-13 1.6hdi 90ps if cheap enough or I'll get the lowered powered one and get it mapped a bit higher. Is that something you recommend?
Threads: 9
Thanks Given: 316
15
Unless you are looking for a very high mileage version of what you are after there are very few problems and no common ones really - rear axles can wear on high mileage ones.
As said ^ service history but also look at the overall condition if the bodywork and interior have been looked after its a good indication it will have been cared for mechanically.
Remember dealer vehicles will cost more but will come with a decent warranty.
