  • 7 Vote(s) - 2.86 Average
curtains
Hi, I have made a sleeping platform to go in the back of my mark 2 but am struggling a bit with curtains. Three main choices: velcro, curtain wire or suction cups. Anyone had any success with this? Big Grin
I'm thinking along similar lines in my Mk3. I'm thinking of not having something permanently rigged, but to use shock cord hooked on at all four corners which I can hang at night, so I don't have curtains flapping around in the daytime. Either way it'll be cheap enough to experiment.
I had a go at this in my old VW Transporter Minibus, I wasnt so very pleased with the result using velcro it was awkward nd often looked messy, suction cups in Spain just didnt work, in the end I bit the bullet and put hook in the metalwork which did the job ok but there were issues with the sliding door catching the curtain.
why not try as a temporary thing magnets, either with hooks attached or just plain square ones. They could even be sewn in to the curtain. would be neat and easily stowable. I havent looked to see if there is enough bare metal in the right places to enable it to work. Just an idea. Confusedcratch:
[-] The following 2 users say Thank You to mrbritse for this post:
  • Ciaran Murphy, ron
Hadn't thought of magnets or shock cords so gives me a bit more food for thought. Going out for the first night on new years eve (the girlfriend is delighted!) and going with the uber bodge of the car cover. Prob ok for one night in winter but not one for the summer ...
You can buy very thin bungee type elastic from a ships chandlers.
That should prove to be a workable solution.
  • Ciaran Murphy
I found this souce of shorkcordnand various useful looking fittings...
http://www.bouncingrabbit.co.uk/index.htm
Magnets is a good idea though - I like that.
[-] The following 1 user says Thank You to nicebiscuit for this post:
  • Ciaran Murphy
The shockcord will pull the magnets unless they're quite large (tried this on another motor). You can
get rigid curtain/net mounts that consist of an oval tube within a tube(telescopic) with eyelets each end. The mounting pins are plastic / metal pin with double sided sticky tape. Make sure the mounting area is immaculate so the double sided sticky gets a good hold. Make a hem on the top and bottom of the curtains, slide the telescopic rods through and hook them onto the mounting pins. The rods are about 10mm x 5mm, come in various telescopic lengths, can be cut with a hacksaw to suit and are only a couple of quid to buy at most big stores and some DIY shops too. Dead easy to mount / remove.
[-] The following 2 users say Thank You to Mindyerlingo for this post:
Sticky backed Velcro type fastening would work if you want them demountable. We use it in the trailer tent or you can try curtain J track riveted in place and the same cut in pieces sewn to the curtain to hold them up. We have used this in awnings as well.
  • Ciaran Murphy
(26-12-2012, 11:22 AM)ffrenchie Wrote:  Sticky backed Velcro type fastening would work if you want them demountable. We use it in the trailer tent or you can try curtain J track riveted in place and the same cut in pieces sewn to the curtain to hold them up. We have used this in awnings as well.
the sticky back never worked for me it just went gooey in the heat and fell off but then I did once leave a cassette (!?) on the front seat and it melted! Got seriously hot there in August.:lol:
[-] The following 1 user says Thank You to mrbritse for this post:
  • Ciaran Murphy
What year was that?:lol:
Haynes K9 online manual
Today 08:34 AM
Wind noise at speed
Last Post: uk_friendly_fire
Today 07:46 AM
» Replies: 15
Service above and beyond - praise for your garag...
Today 07:25 AM
All audio and radio stopped working
Last Post: Ashcrouch
Today 06:53 AM
Locked car while driving.
Last Post: Anyinfo
Today 05:34 AM
Fitting USB Box 9702.EZ to B9 Berlingo/Partner
Last Post: B9_Driver
Yesterday 10:11 PM
Hi
Yesterday 09:46 PM
Anyone have plans for a simple camper unit
Last Post: jtr rhyl
Yesterday 08:49 PM
» Replies: 52
What head unit stereo is this
Yesterday 07:57 PM
Boot/tailgate won't open - handle doesn't releas...
Last Post: jtr rhyl
Yesterday 12:10 PM
