Threads: 7
Thanks Received: 3 in 3 posts
Thanks Given: 4
Has anyone had a rattling spare wheel carrier?
I'm tempted to jam in some form of bung unless someone has a more elegant solution?
Thanks.
2011 XTR 90
Threads: 7
Thanks Received: 29 in 25 posts
Thanks Given: 43
20-04-2015, 12:01 AM
(This post was last modified: 20-04-2015, 12:02 AM by ddb.)
Interesting question, I've got a rattle on one (2009 XTR) that just sounds like spare wheel rattle but (non-citroen) garage insisted it isn't but couldn't find what it was , Citroen said noise it was a "feature" and nothing to worry about.
If you know it is spare wheel rattle then I will be having a look myself.
Mar 2002 Berlingo Multispace Forte 1.9D 166,000 miles
Threads: 7
Thanks Given: 4
Thanks polar. Plastic ratchet clips? Not sure what you mean exactly, would cable ties be a decent subsitiute?
ddb, yes definitely the tyre carrier, confirmed by local (independent) garage; not serious apparently just annoying!
The following 1 user says Thank You to JT1 for this post:1 user says Thank You to JT1 for this post
• ddb
Thanks Received: 22 in 16 posts
Thanks Given: 36
20-04-2015, 05:35 PM
(This post was last modified: 20-04-2015, 05:36 PM by jayjay2cv.)
Where abouts does it rattle from?
2014 Berlingo Multispace 1.6 e-Hdi XTR ETG6
Thanks Given: 189
44
Try removing the unit entirely to eliminate it.
Threads: 10
Thanks Received: 10 in 7 posts
Mine came with such a rattle. The cause? The spare wheel had the wrong sized tyre fitted and the looseness was causing the cage to sway. Someone had actually padded out the space with rolled up rubber mats instead of just fitting the correct tyre... Just typical of the kind of nonsense you find whenever you buy a used car and one of the reasons I try not to do it too often!
____
2010 B9 Multispace VTR 1.6 Petrol 90hp
