  • 24 Vote(s) - 2.88 Average
picture of new Berlingo
I don't know what I'm doing but hopefully there a picture of my new Berlingo. It is semi- auto in that you select auto and it drives like an auto but unlike other auto's it has the normal gearbox (6 speed) with a normal clutch operated by means other than your left foot. It has a manual setting with paddles on the steering wheel but I leave it in auto. That, coupled with a sat nav beats driving through Amsterdam with a street map on your lap , and shuddering along in top gear at three miles an hour because you don't know where you are and you've got a belgian truck up your tailpipe.
tintin
( I think I'm doing something wrong as nothing happens when I press " insert into post" even though there is a picture showing.Tinypic is not doing it's job )
(23-11-2011, 12:08 AM)tintin Wrote:  I don't know what I'm doing but hopefully there a picture of my new Berlingo. It is semi- auto in that you select auto and it drives like an auto but unlike other auto's it has the normal gearbox (6 speed) with a normal clutch operated by means other than your left foot. It has a manual setting with paddles on the steering wheel but I leave it in auto. That, coupled with a sat nav beats driving through Amsterdam with a street map on your lap , and shuddering along in top gear at three miles an hour because you don't know where you are and you've got a belgian truck up your tailpipe.
tintin
Hi, hope you enjoy the semi-auto, i find it a lot easier too. Sorry but no picture yet.
[-] The following 1 user says Thank You to taxi for this post:
  • tintin
Hi TinTin! Here's a link to a post on how to post an image:
http://www.berlingoforum.co.uk/misc.php?...help&hid=8
Hope this helps!:thumbsup:
  • tintin
(23-11-2011, 01:28 AM)OlJeffers Wrote:  Hi TinTin! Here's a link to a post on how to post an image:
Thanks OJ, definitely my pal for knowing the docs.
Op, follow the info and it should help you out!
[-] The following 1 user says Thank You to Andre for this post:
  • tintin
Has the semi auto got a clutch?
I DO MISS MY BERLINGO Heart
(23-11-2011, 09:42 AM)philip Wrote:  Has the semi auto got a clutch?
Yes. Please, read this post:
http://www.berlingoforum.co.uk/showthread.php?tid=1452
hi Philip,
Yes it has, but no clutch pedal. The clutch operates by electronic/electric/mechanical means - solenoids,servomotors ,I don't know exactly but I had two campervans , which had similar systems - Sprintshift on a Merc and Tipronic on a Volkswagen. I never used them in their manual mode i.e shifting up and down the gears by means of two paddles on the steering wheel (same as my Berlingo) because the auto knew exactly when to change gear and ,in fact, I found it to be the most economical mode as well as being more relaxing to drive.
tintin
hi Philip,
tintin
OK im with you know, its the same idea as VW and Skoda auto boxes. They say you don't use as much fuel as the conventional auto box.
picture of new van[Image: 2n21j5v.jpg]
Could you or someone else post a pic of the dash set up where the gear stick normally is?
Van front seat conversion to 3 seats
Last Post: Golfbuggy
Today 03:41 PM
Mk3 berlingo (2019) "boot jump plans"
Last Post: celyth
Today 08:26 AM
Brake lights in spite of changed BSI - need advi...
Today 07:14 AM
Serpentine belt cover screws
Yesterday 07:00 PM
The creation of my personal solo-travellor.
Last Post: EM58
Yesterday 05:10 PM
» Replies: 19
No brake lights
Last Post: uhurusurfa
Yesterday 02:47 PM
Online parts. Where are people buying from thes...
Yesterday 12:44 PM
Are brake pistons / seals a common size?
Yesterday 12:18 PM
Column Universal Joint
Last Post: pondweed
28-04-2024 01:00 PM
Touchscreen Version
Last Post: sswindon
28-04-2024 12:03 PM
