Hi everybody, can you please advise if those hub center caps will fit on Berlingo '07 1.6 HDI? Actually i have normal wheels covers on black iron wheels. Thanks a lot in advance
16-03-2021, 06:37 PM (This post was last modified: 16-03-2021, 06:38 PM by saskak.)
Unfortunately, I have no answer to your question as I am looking for the same thing. Centre hub caps for the 15inch steel wheels to cover the bolts and the centre. Most bigger vans have these.
Thanks by the way, I've found them on the bay. Another solution can be those, but except that they are a quite expensive (they are made out of steel, ok) i don't know how they look like.
(16-03-2021, 07:01 PM)Metamatix Wrote: Grazie a proposito, li ho trovati sulla baia. Un'altra soluzione può essere quelle, ma a parte il fatto che sono piuttosto costose (sono fatte di acciaio, ok) non so come siano.
(16-03-2021, 05:45 PM)Metamatix Wrote: Hi everybody, can you please advise if those hub center caps will fit on Berlingo '07 1.6 HDI? Actually i have normal wheels covers on black iron wheels. Thanks a lot in advance
That should tell you if it has the same PCD as yours and then you'll have a good chance of know if the caps will fit the wheel bolts. Can't be certain that the rims are the same though.
This is very helpful, i know that they are for berlingo '08 and as per comparison they have the same measures of mine which is a' 07. I'll study more deep and I will revert soon. Thanks again, great forum.
21-03-2021, 09:39 PM (This post was last modified: 21-03-2021, 09:42 PM by Sol.)
(21-03-2021, 07:09 PM)Metamatix Wrote: Ciao amici, finalmente ho acquistato il tipo come da foto. Non appena arriveranno, ti terrò aggiornato ??
Please post only in English on the forum, thanks.
