ABS System Fault in mfd
Have an abs fault in my display with a few weeks,mechanic told me it's a control unit which is about €600!,any one ever have this issue?
have you had the fault code properly checked, theres a few things it could be
Must ask my technician what the code was and I'll post
Got to agree with getting code checked. I was told that I possibly had a control unit failure, but problem turned out to be a faulty connector between wiring harness and the front abs sensor. I then had further problems but some were my own making from making/breaking connections during fault finding, and stuffing my multimeter into connectors, thus damaging contacts.
A good auto electrician with access to code reader might be your best bet. You should be able to find my posts
My Berlingo Multispaces
Yesterday 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
