Threads: 8
Thanks Received: 7 in 4 posts
Thanks Given: 7
Quick question; is it possible to change the rear brake cylinder without dismantling the brake shoes. i.e. slip the shoes off the cylinder, change it and then slip them back on?
Apologies if this is a stupid question
Berlingo 1.6HDi Dangel 4x4 120bhp
Threads: 5
Thanks Received: 131 in 115 posts
Thanks Given: 3
19
It's possible, but I find it easier to take the shoes off. If they are contaminated with fluid, they will need replacing anyway
Threads: 62
Thanks Received: 715 in 612 posts
Thanks Given: 219
50
Why waste an opportunity to do some worthwhile maintenance while you have the access.
Serieal Berlingo owner
Threads: 8
Thanks Given: 7
Because whenever I take brake shoes off the replacing of them entails a lot of swearing and the pinging of springs all over the garage. That is if I can actually work out or remember where they were from in the first place.
The shoes aren't contaminated. It is a very small and recent leak.
Threads: 8
Thanks Given: 7
(11-12-2015, 07:16 PM)geoff Wrote: (11-12-2015, 07:08 PM)Nicepix Wrote: That is if I can actually work out or remember where they were from in the first place.
Digital camera or mobile phone helps enormously here ...........
Tried that. Still got the picture. But it doesn't show what is at the back
Its all those self-adjusting bits and those little caps you have to compress over the springs while holding the pin in place at the back and PING!! Now where's it gone?
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
eurocarparts has a tool (@£6.00 ) just for the washers on spring retainers. I used to have one until somebody thought they needed it more than me. Ideal for doing them awkward blighters
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
It is easy to remove the slave cylinders without removing the brake shoes just adjust the shoes out replace cylinder then reset the adjusters on the shoes.
However if you find it difficult to replace brake shoes do you think you really want to tackle changing the wheel cylinders?
Threads: 8
Thanks Given: 7
(11-12-2015, 08:05 PM)brodfather11 Wrote: eurocarparts has a tool (@£6.00 ) just for the washers on spring retainers. I used to have one until somebody thought they needed it more than me. Ideal for doing them awkward blighters
(11-12-2015, 09:10 PM)polar Wrote: It is easy to remove the slave cylinders without removing the brake shoes just adjust the shoes out replace cylinder then reset the adjusters on the shoes.
Brake cylinders don't have springs. And there is only one part to worry about
Threads: 62
Thanks Given: 219
50
I just use my fingers to hold / push / turn the spring retainers, you lot need more Weetabix !!!!!!!!
