  • 15 Vote(s) - 3.33 Average
Both Break Lights Not Working
just looking for some info on this ,I have been doing a lot of research :eek:on this ,
my both brake lights are not working and i have change the bulbs but still not working , Im thinking that it might be brake switch can any1 advise me on how to check this( I know its somewhere near the brake pedal) or is it a fuse ,
Thank you in advance for help .
oh yes my van is up for psv on friday would like to get it passed so i dont fork out £18 for retest Confusedcratch:
Should be a free retest, shop around, what are you paying at that garage?
Does the top brake light work? Most likely your brake light switch which is just above the pedal itself IIRC.
The switch is on the pedal box.Disconnect the plug,join the two plug terminals with a handy bit of wire,turn ignition on,run round the back & check if stop lights are on.If they are,check the switch plunger is free.They can get dusty etc & stick.If it's sticky,squirt Wd40 on it while pushing it in & out(the plunger).Try before refitting.As a rough adjustment push the pedal 2-3mm before the plunger touches it.Good luck & welcome to the forum.
(07-01-2012, 11:33 PM)ron Wrote:  The switch is on the pedal box.Disconnect the plug,join the two plug terminals with a handy bit of wire,turn ignition on,run round the back & check if stop lights are on.If they are,check the switch plunger is free.They can get dusty etc & stick.If it's sticky,squirt Wd40 on it while pushing it in & out(the plunger).Try before refitting.As a rough adjustment push the pedal 2-3mm before the plunger touches it.Good luck & welcome to the forum.
do you think that it is most likely it is brake switch ?
and do i need to unscrew the 2 screws from the fuse box to get at the switch ,
I took off the brake switch to have a look it seems that the plunger (the bit inside the black thread) is flush at the end , I tried to free it abit with wd 40 but it doesnt seem to come out a bit further ! Does this mean i need to get new brake switch ?
I had looked at some of the pictures on ebay of brake switches and it looks like that the plunger seems to be further out more .
Thanks guys in advance
(08-01-2012, 11:48 AM)Raymi5 Wrote:  ! Does this mean i need to get new brake switch ?
Yes. Switch must be replaced.
Thank you very much you guys :thumbsup:
pk7478
ron
Andre
I will get one asap for psv on friday , I will let you know if brake lights working when I get the switch .
M59 1.4 Petrol question
Yesterday 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
